time2roll
Oct 23, 2014Nomad
Empty Nest, Soon wrote:Best to attach in a balanced manor or at each end of the stack. Without a pick I can't really know what two are where electrically. At 40 amps into four batteries it is not going to be a huge difference like the 100 amps from inverter. Charge in the mornings and let the solar balance things out the rest of the day.
Question: Does it matter where in the parallel circuits I attach the portable charger cables? I find that the existing cables are routed as follows: Red to battery 1, then battery 2, then cables from 2 to both batteries 3 and 4. Black to battery 4, then 3, then 2, then 1. The closest terminals to hook the clamps for the portable chargers are on batteries 2 and 3. Batteries 1 and 4 are in the back of the drawer.
In order to treat the batteries kindly in recharging, can I attach my charger clamps at batteries 2 and 3, in the front half of the drawer, or should I bother to reach to the back to charge at the same terminals the built-in charger uses, on batteries 1 and 4?
Thanks,
Wayne
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
