CA_Traveler
Jun 06, 2022Explorer III
You are charging it correctly, 12V charge for a 12V battery or 2 6V in series. The 6V setting can be used to charge a single 6V battery.
Any basic VOM will be useful and one that can measue amps are usually limited to say 10A and can be helpful. Further up the food chain is a clampon ammeter that makes measuring amps so much easier and for much higher amps. Make sure you get one that measures DC amps, many for electricans measure only AC amps and labeled DC since they can measure DC volts.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
