valhalla360
Jun 10, 2022Navigator
Vintage465 wrote:Boon Docker wrote:
So someone split my 12 volt battery in half. :E
Must have been the previous owner.
Think of it using this analogy.....One 12 gallon gas tank......used it for 10 years, rusted out. Replaced it with two 6 gallon gas tanks linked together. They're still 6 gallon tanks, but they equal 12 gallons. Same with the battery. No doubt the coach came with a 12v. Someone wisely(in my opinion) replaced it with two 6v's wired to equal 12.6v,+/- to be compatable with a 12v system. All is good, no technical or mysterious discussion necessary......
Now you go and make an incorrect analogy that make's wa8xms point relevant. ;)
If you have 2 - 6gal tanks and one is empty, assuming you only need to go say 20miles, you have full capability (I'm assuming you get better than 3.5mpg).
If you have 2 - 6v batteries and one is damaged, drained or otherwise taken out of service, you can't operate even if the remaining battery if fully charged and in great condition.
What you are describing would be 2 - 12v batteries. You can wire them in parallel which would be equivalent to pulling off of both 6gal tanks simultaneously. Or you could put in switches/valves, you can choose one battery/tank to operate off of and when empty switch to the other.
But for the OP, he has 2 - 6v batteries wired in series to put out 12v power.
- If he asks a question and describes it this way, he is likely to get good advice.
- If he says he has a 12 volt system with 2 batteries, there is a very good chance, people will assume 2 - 12v batteries wired in parallel and the advice will be wrong.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
