BFL13 wrote:
http://www.boatandrvaccessories.com/powermax-pmbc-55adj-converter.html
Several errors in this ad. The dealer is mixed up. It is as I described earlier.
I would ask if you can get a better price if you don't take the cables. Make your own out of cut off jumper cables. Suggest #4 cu, not the #6 in the ad to get the most amps.
Similar but don't know shipping cost
http://www.bestconverter.com/Boondocker-BPCM-60-60-Amp-Adjustable-Power-ConverterCharger_p_585.html#.WIURUEczVpw
BFL13 you're very familiar with this group of chargers and I believe it was you that mentioned that somewhere around 70amps and above a 20a circuit would be needed to run those chargers....which seems reasonable. All 4 of these adjustable voltage models, 55a, 75, 100a, and 125a mention 7amps. Could that be true...am I not understanding correctly?
I've pestered both boatandrv and powermax for a manual but no luck so far.
