wa8yxm
Sep 12, 2015Explorer III
I think he is saying he has an 18 volt DC/DC converter for his computer
The answer to his quiestion is yes, Micro-Center among other computer stores sells a "Universal" computer adapter it is a DC/DC converter with adjustable voltage and a selection of "Tips" (plugs for the device) I'm sure it would work.
Radio Shack used to sell one as well (or two)
HOWEVER. what I'm not sure of is the proper voltage to set it at. .IF the drill is a 20 volt drill then you will need something higher (Perhaps 25 volts) to charge NOTE The Perhaps is not intended as instruction only example I can all but guarantee it is the WRONG voltage,, not sure what the proper feed is.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
