westend
Jan 20, 2014Explorer
Here's my regimen when the lights are left on in a vehicle and assumes a battery in the middle of it's life cycle: Remove cell caps and check water level, hook up shop charger at the 10 amp rate (mine really pushes the juice), Read the amperage meter on the charger and I can usually tell SOC and what the battery is doing. Measure with a meter, if handy. For a good sized truck battery, I leave the charger at 10 amp for 1-2 hrs. Occasionally, while I'm keeping my eye on the battery, I'll flip the charger over to the 200 amp rate, momentarily. After an hour or two, I check water level, fill if necessary, and I select the 2 amp rate letting it charge overnight. If the battery is older it may need another dose of the treatment above.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
