BFL13 wrote:
You could get the variable voltage model of that PM one which does not do the three or four stages automatically, but then you have to be there at the end of the four hours to drop it to 13.6 yourself. That one does let you choose higher than 14.6 for your Vabs. Once you set it to 13.6 it will stay there. You can pick another Float voltage depending on the temperature where you are.
BFL, how long does it take to get your bank to 14.7 or whatever bulk voltage you use on your battery bank? I'm interested in the PMBC (whatever the variable voltage one is called) but only if I can get my bank to 14.8 or so in 3 hrs from 50% SOC.
EDIT: I could put a timer on it if I can't babysit the converter.
