mena661 wrote:
smk wrote:
Not sure PM is best as I believe it drops to float as soon as the set point is reached. OK maybe you can then adjust the float up to 14.7 for a few hours but that seems like the wrong way to me.
The adjustable one is not an auto 3/4 stage charger. You have to manually set the voltage for each "stage". That's why I want it. I'm at the point now where I'm just not happy with converters and can't justify inverter/charger units with the programmable time and set points. And I'm tired of waiting a week to charge up my batteries to full (letting the converter float for a week then pump in some volts for finish charge). If I can get all this done during the first day or two after a trip, I'll be happy. Not to mention, I can change the float voltage. That right there is reason enough to get one of these. No more 13.6V float (WAY too high) when it's 110F outside.
Spend the money on Solar. 210/250w panel, 20a Rogue controller, Done.
Fully automatic recharge at home and some boost while camping. Full temp compensated etc.
Probably work well for the OP also :B
