I did not get a chance to call the Odyssey tech line today, but on this chart I posted before:
It says 0.4c Min with a little 10 next to it, on the right side, next to the dotted line indicating current.
Not sure what that 10 means.
I might take the day off tomorrow and go get some AGM batteries after making some calls. My engine starting battery is dropping to 6 volts during 1.5 seconds of engine cranking, and my house batteries are currently reading, as I type, 12.1 under a 10 amp load with 14A/h removed from them. I was plugged in the last 2 days, Schumacher running. So they were full or very close as it did decide to do the 10 amp thing at 15.4 volts for 2 hours after a normal recharge.
US battery has a group27 AGM. Not sure of the price, but I found their spec sheet which lists charging requirements.
Less than 27 amps initial current, but they say 14.4 to 15.0 for cyclic use and 13.5 to 13.8 for standby.
My alternator might be able to produce slightly more current at higher rpm than this rating( 3 batteries) but it is within the vehicle's normal voltage range.
A 68 amp hour AGM battery with 930 CCA claiming a 0.4c minimum charge rate
Vs a 99 amp hour AGMbattery with 750CCa and a ~0.3c Maximum.
That's where I'm standing.
I hope the price is right on the USbatteryAGM
http://www.usbattery.com/usb_images/usb_agm_27_12volt_spec_Low.pdf
