time2roll
Oct 25, 2014Nomad
Lots of amp readings. Not much on voltage. When the batteries are low and you start the generator make a voltage measurement at the converter and at the battery while the converter is in boost mode. You should easily get 40 amps into the battery or there are issues to solve or improve.
