enblethen
Jun 04, 2023Nomad
Need to determine the charge rate of your converter. Many have converters rated around 35 ampere output. This in many cases is not sufficient. Adding a separate battery charger isn't going to help much as the normal safe charge is around 10 amperes.
While boondocking refer should be set on auto. When genset is running, the refer would run off 120-volts AC.
1000-watt generator maybe a little small.
My thinking changing the converter to say a 50-ampere output would help.
