- pianotunaNomad III
swimmer_spe wrote:
OP here.
If while the generator is running, I turn off the fridge (pulling the fuse if need be) would that give me a better charge?
If the generator is able to power both the fridge and the converter (rv speak for battery charger) then shutting off the fridge will make no difference except for a tiny bit more fuel used. - swimmer_speExplorer
Matt_Colie wrote:
Swimmer,
You have a wonderful collection of inadequate information for your responses.
First problem: Lead Acid Flooded batteries can be charged to about 90% State of Charge (SOC) in a couple of hours depending on the battery temperature. That last 10% takes most of five hours and can't happen faster without the heat damaging the battery.
Second problem: That 1000w generator is about 60 amps at 13.5V (for a 12V system). Your electric refrigeration is probably about 120W (about 10 amps) on a duty cycle that is related to temperature and use. So, it will suffice and larger generator won't get you any advantage.
Third problem: Will you be able to run the generator all the time you need where you are going? Many places have quiet hours.
My guess based on my experience is that if you run the generator at least 12 hours a day, you should be able to survive.
You gave us no clue what the reefer is or what your house bank is, and it does not make a huge difference.
If you know more, come back and we can probably get you a better answer.
I plan on using it when hunting on crown land. So, if need be, it can be run nonstop.My plan is to fire it up when we get up, and leave it running till we get back from hunting. - Matt_ColieExplorer IISwimmer,
If you know more, come back and we can probably get you a better answer. - swimmer_speExplorerOP here.
If while the generator is running, I turn off the fridge (pulling the fuse if need be) would that give me a better charge? - valhalla360Navigator
pianotuna wrote:
1 or 2 batteries is minimal for boondocking. I started with 7.
If only boondocking for a night or two at a time, silly to spend the money and drag around a huge battery bank.
We have two and for an overnight, we run the fridge and a big of furnace and the next morning we are typically at 12.5-12.6v. - valhalla360Navigator
Boon Docker wrote:
Until the batteries are fully charged. :B
With that small genny and electric fridge plus other power usage, I would say the genny needs to run most of the day.
If you want the battery truly at 100%, yeah you will need to run it all day but really a waste of time and gas. As lead acid batteries near full, they will accept fewer and fewer amps, so the last 10-15% takes many hours. Pretty much no one boondocking will use a generator to get to 100%. Just get it up to 80-90% and call it good.
Getting up to 80-90% should only take 2-3hours if putting in 30-40amps in the bulk charge phase.
If you really want to try for 100%, get something like a 100w solar panel. Run the generator for 2-3 hours in the morning and then let the solar slowly top up the batteries over the rest of the day. - ScottGNomadYou will be very close on capacity with that gen.
- pianotunaNomad III1 or 2 batteries is minimal for boondocking. I started with 7.
- theoldwizard1Explorer II
Some small generators have a 12V DC output. DO NOT USE IT !! Use a standard AC powered charger.
The original question is too vague. Too many variables. - I would not count on more than 30 to 35 amps into the battery from a 1000w generator.
Minimum three hour run time. Possibly twice a day.
Post the existing charging system for best answers.
Having RV issues? Connect with others who have been in your shoes.24,292 PostsLatest Activity: Jul 30, 2025
