pinesman's avatar
pinesman
charging batteries with truck
Several years ago when the fifth wheel that I had at the time only had room for one battery, I carried 2 more in the back of my truck. I used 2 sets of good jumper cables with ring terminals on one end and winch connectors on the other end to supply extra battery power when dry camping. Fast forward a few years and my current trailer has room for 4 batteries so I do not use the cables like I used to. However, I got to thinking about using those same cables to charge my batteries using the truck. I would not be using it for hours to run everything
but just a little while to top off the batteries in the trailer. Has anyone done anything like this?
  • It can certainly be done. Use good jumper cables right off your truck battery to the trailer batteries.
    The however in this case is your truck engine is producing a substantial amount of power just to run it's engine. A 2K generator will produce much less power and it's easier of fuel to run. The battery pack will take a charge at the same rate from both. One engine uses a lot more fuel than the other.
  • Seen it often where folks use jumper cables from truck battery to trailer battery for a quick recharge. Theory is the jumper cables are shorter and fatter than the long skinny wires back to the 7-pin.
    Neither method gives you much of a recharge, but it can keep you going. Better to have a small generator and use your converter for a higher amp, faster recharge. Solar can sometimes help too.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
