coolmom42
Oct 22, 2014Explorer II
MEXICOWANDERER wrote:
A question is, with one thousand watt limit what are the options in a power factor corrected charger dept? Trying to recharge 100 amp hours at 30 amps is dooming the user to listen to the generator for four hours at a stretch to charge to 75-80% with regular batteries and perhaps 80-85% with AGM. I would be -mighty- tempted to fit a 140 amp alternator to that van and let it whack the AGM's for a half hour while concurrently running the Honda. But there is a finite amount of amps that a Honda 1000 will ignite and if memory serves me correctly that figure is 50 amperes or less
I'm looking at the Nissan NV or Ford Transit vans, and they generally do have a heavy-duty alternator. That's on the list to double-check when serious van-looking time arrives.
They also have a built-in inverter that would allow me to plug in the battery charger at any time the van is running. The inverter plug-in while driving would be a good way to top off the batteries, since most days I will be driving some.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
