time2roll
Jun 02, 2016Nomad
800 watts is good for about 30 amps into the battery. A good chance the converter will overload the generator with a low battery. Use the portable assuming it is 15 to 30 amps output. Just connect it on the battery direct, no need to remove anything.
Once voltage gets up in the 14.2+ range continue for one more hour.
Most likely the converter would quickly taper to a trickle charge at 13.6 volts.
Give it all a test before you go.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
