mbopp
Jun 02, 2016Explorer
First problem - it looks like you have a WFCO converter. These are known for NOT going into Boost mode when charging.
Second problem - you probably have 8ga wire from the converter to the battery. That results in too much voltage drop for good charging.
I'd go with using a good battery charger directly connected to the batteries.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
