BFL13
Jan 16, 2018Explorer II
EdTheEdge wrote:pianotuna wrote:
With 2 hours per day you do NOT want a battery tender. Use the converter, or use the biggest meanest battery charger you can find.
ATM I only have a Battery Tender Jr.... I will use the available 120v to charge the house battery while I am there. Sometime in the future I will get a better charger.
What's the matter with the converter? Also have you tried using the converter and battery tender at the same time to see if they add their amps at all? Plus any solar. ( You need a low battery to do such testing so it will be sure to accept all the amps you might get in various combinations of chargers)
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
