joraz's avatar
joraz
Charging Dash A/C
My dash A/C works great although it will lose some R-134A over several months time. I added a can and a half about four months ago (hose with vale and gauge from auto store). I noted at the time that the low pressure side was holding about 37 psi. Anyhow, just recently it started blowing a little less cold than normal. I added one can and got it up to around 30 psi. Then I started the second and checked the pressure as I did so. (shut valve, let settle, check) It was at this time that the pressure reading started bouncing from 25 or so to 35 or so. Anyhow, I didn't add any more and the A/C is operating fine so what's the deal? Thanks.
jor
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
