MEXICOWANDERER
Sep 15, 2014Explorer
Can you rig up not toy jumper cables or move the battery to use cables? This battery can accept a 60 amp charge rate easily. You may get 25-30 amps with a long run of 8 gauge. Three times the time needed to recharge versus jumper cables. Later on, you can run six gauge and a 80 amp breaker at each end for protection. This will fill the battery as fast as safely possible.
