kerrlakeRoo
May 21, 2017Explorer
First thought, try a voltage check on the battery, with truck disconnected and shore power off, then connect truck and check again to ensure you are getting a good connection to the truck. Voltage should come up from 12.5 or so disconnected to 13.8-14.2 with truck connected and running.
Slide problem is a possible nicked wire. whenever you are dealing with powered moving parts the possibility exist.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
