kerrlakeRoo
May 21, 2017Explorer
theoldwizard1 wrote:kerrlakeroo wrote:
First thought, try a voltage check on the battery, with truck disconnected and shore power off, then connect truck and check again to ensure you are getting a good connection to the truck. Voltage should come up from 12.5 or so disconnected to 13.8-14.2 with truck connected and running.
That voltage will keep a house battery from going dead, but will never fully recharge it.
I understand that, but his question was recharging from truck, Voltage should increase unless a problem is in the system, blown fuse on truck, loose connection on 7 pin plug, nicked wire somewhere in the lines. I was just trying to narrow the scope to a single part of the system.
Or, is the problem strictly on the 5 er, gotta start somewhere and my first thought was narrowing whether its the truck or trailer.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
