kerrlakeRoo
May 21, 2017Explorer
JHblack wrote:
I will disconnect , shore power, check Battery volt the. Connect to truck to see if volts rise. If not I'm guessing I have a plug problem.
Yes
plug or truck or wire from plug to battery.
There is a fuse for the trailer power lead that could be bad, the plug itself Pin 4 and then the wire from there to 5er battery, you will have at least isolated to there.
If power doesnt go up check pin 4 if no power there on truck side the fuse is blown 30 amp in fuse holder slot F30
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
