Terryallan
May 21, 2017Explorer II
JHblack wrote:
To a Terry Allan. Never new truck had to be set up to charge battery, as it kept it charged for multiple trips. I guess I could have been running Strictly on battery but it's just recently started.
Don't know what you are driving. But if it is a Ford. there is a relay that has to be installed to charge the battery. Easy to check. Find the hole in the fuse panel, or check the charger pin in the TV 7 pin.
Also IF the battery was good. It would last hours with only the fridge running off propane. When is starts going bad. Not so long
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
