KD4UPL
May 21, 2017Explorer II
So you're trying to run the refrigerator on DC while running down the road? There's your problem. The refrigerator likely pulls around 30 amps of current. This is more than the small wiring in the truck and trailer charge circuit can supply. Even if all your fuses, wires, etc. are fine as people have suggested you check it won't keep up. You must run the ref. on LP when traveling. Or, you have to seriously modify your tow vehicles charging circuit with very large wire, fuses, and connectors.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
