theoldwizard1
May 27, 2017Explorer II
kerrlakeroo wrote:theoldwizard1 wrote:kerrlakeroo wrote:
First thought, try a voltage check on the battery, with truck disconnected and shore power off, then connect truck and check again to ensure you are getting a good connection to the truck. Voltage should come up from 12.5 or so disconnected to 13.8-14.2 with truck connected and running.
That voltage will keep a house battery from going dead, but will never fully recharge it.
I understand that, but his question was recharging from truck, Voltage should increase unless a problem is in the system, ...
Not true anymore. Abuot 10-15 years ago, all light/medium duty vehicle manufacturers went to "smart" charging system. A few minutes after the engine is started, the output from the alternator and its internal regulator will be about 13.6-13.8V. Certainly less than 14.0V.
Not enough to properly recharge a deep cycle battery bank to is at 50% DOD.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
