BFL13
Jul 07, 2014Explorer II
My GC2s are doing well with solar while camping where the controller takes them to 14.8, then drops to float (with no absorption time at 14.8) of 14.4 for the rest of the day (except for times at loaded voltages when using DC stuff). The SG gets to baseline by dark if the time at 14.4 is from mid-afternoon or before.
So IMO don't sweat the details of the Rogue so much, the batts will do ok as long as they are getting "something like that."
13.6 for float while camping is too low IMO. You need as much time in the 14s as you can get. The voltage drops overnight, so that is your actual "float/take a break" time for the batts.
Storage is different from camping. Now you don't want a prolonged time in the 14s daily.
Your decent SG tool is a $6.00 hydrometer--the glass tube with the bobber showing green white red and numbers, not the useless plastic flat bulb with the sideways needle type.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
