Almot
Jul 08, 2014Explorer III
brulaz wrote:
now I've been convinced to boost my float even higher when camping.
Either this, or leave it slightly below the recommended 1%C. When you are "camping", rather than just "charging", there is always some load even when you've turned off everything you could. Fridge, LP sensor, and self-discharge alone can draw 0.8-1.5A. So if you set FLOTR to 0.5A, it will never drop that low, and then timer function FLOTM will run 2 hours just like you wanted.
This controller has probably more adjustable parameters than any other MPPT, and they are easy to play with because of built-in interface.
The ultimate choice will depend on the SG results. I can't measure it in my AGM, so I'm relying on battery specs and rested voltage in the morning. But you can.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
