simple274 wrote:
I need to charge my house batteries, (not my chassis battery).
Will that Trik-l-start charge my house batteries as well.
And if so how will it hook up.
First post said you needed the chassis battery to charge from the house battery system. Or did I read that wrong?
To charge the house battery, just plug in the main cord. Or are you saying the house battery is not charging off the alternator? It does take a bit of time.
Trik-L-Start just sends a few amps from the house to the chassis battery while you have the main cord plugged in or the generator running. It is not actually a charger. It just connects the batteries when charging voltage is present. Will not allow house battery to pull down the chassis when camped off grid.
