MEXICOWANDERER
May 05, 2021Explorer
Landy used some of my suggestions on his Meanwell. The chokes develop the most heat. A 600 watt uses a blow out fan but a 80mm suck in fan in front connected to the original fan electrically lowers internal temps 40°F. I have a 150 watt 36 volt meanwell that warms up too much on a 50 watt LED load. No fan.
I original 36-amp Megawatt was souped up to provide 56 amps continuous at 15.5 volts. It's on it's 4th year. Nicknamed the HYPERWATT. The Delta power distribution on pos and neg are similarly inversed into 3 into 8 gauge power wires.
The 14 amp is a garden hose on a fire truck.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
