BFL13
May 05, 2021Explorer II
I think you are supposed to leave it on at its 14.2 for a while so it has time to do the balancing trick and then leave it on a bit longer before dropping to float or stopping the recharge so it gets to 100%. Then you can reset your AH counter to zero. (called sync by some)
Will it do the balancing trick at 14.2 or does it have to be higher?
LFP guys can advise on that. I am unclear how you can tell it is doing and then finishes the balancing trick with your particular battery and collection of meters, so somebody should be able to advise on that too, if your info on that is not clear.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
