StirCrazy
May 06, 2021Moderator
BFL13 wrote:
IMO it is important to call tech support and get balancing clarified as to how to tell it did that. You need to do balancing every so often.
if you get a battery that doesnt have active balancing in the BMS I would take it right back. most people want a drop in and forget battery and a proper LiFePo4 will be this once you get a proper charger as the BMS will be ballancing every time you are charging. some people like doing the balancing them selves but for me when I can have a computer chip do it why should I go through the time for that.
and why wouldent you use AH to decide your state of charge on a LFP ? they do have meters that read that to and it does work....
Steve
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
