mchero's avatar
mchero
Charging my Interstate wet cells
Have a Xantrex Freedom inverter/charger that's not charging my Interstates at proper voltage. As per the specs Interstate guy handed me they should bulk up to 14.8 but looks like the Xantrx only gets them up to 14.2
Unfortunately, I cant set a custom charge rate on the Xantrex, just battery type.
During the day my Classic Charge controller charges them and I can set the proper charge rate. I did that last night and I'm waiting for them to go into float so I can get a proper temp corrected specific gravity.
We are off grid and in the PM when I start the genset for the evening charge I typically run the generator till the Xantrex kicks into float.
I want to get those buggers up to capacity so it looks like I'll be shopping for a 3 stage charger that I can custom program. I need one that will also output the amps so I don't have to run genset longer than needed.
Id LOVE to upgrade the Xantrex but currently don't have the funds.
Also, if the Interstates are toast it looks like I might be purchasing Sams Club 6 volts or perhaps pickup some t-105's
Suggestions welcome!
Thanks All!
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
