mchero
Nov 07, 2016Explorer
I'm having zero issues with the solar side. Does a fantastic job charging the Interstates during the day.
It's when I start the genset for my "evening charge" the one that gets me thru the dark nights out here! The Xantrex is only pumping them up to 14.2 not the required 14.8 I think I'll pull the temp sensor to get a tad more Absorb voltage.
I will take a look at BFL's suggestion.
Solar got them up to 14.8 for about 2 hrs but then the sun starts to go down. so I can't use the Classic to do an EQ charge.
If I pull the temp sensor it will Absorb at 14.4 Now "IF" I could somehow fake the temp sensor into thinking the bats where at 50 deg F it would Adsorb at 14.8
Still trying to figure out what the Xantrex EQ voltage is
Thanks guys
Thanks guys
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
