Old-Biscuit wrote:
Your charging problems are that WFCO that is NOT charging......when on shore power or running generator the WFCO converter/charger is suppose to charge the batteries.
Check that the WFCO is getting 120V AC power (feed from an AC circuit breaker directly or thru an outlet it is plugged into)
With AC power to it.....should have at minimum 13.2 V DC on the output with batteries disconnected.
Best scenario....yank it our and replace with the PD
9260
X2. Your description says either the WFCO is not getting 110VAC from generator/shore power or it is broken.
