Almot
Feb 24, 2018Explorer III
Common recommendation from wet cells manufacturers is max charging current 20% of capacity. If all you have is a single 90-100 AH battery, then 20 amps is fine, and 50 amps is a bit high. Though BFL13 here would probably disagree.
I am not convinced that 30-40A converter would charge at a "much lower rate" than 10A. Correct charging voltage with converter is another question, though.
In any event, offgrid camping with a single battery is not an optimal scenario.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
