time2roll
Mar 25, 2017Nomad
Anything 14.3 to 14.8 should be fine. I have mine set toward the low end.
Even more important IMO is the programming to adjust absorption time based on the start voltage. This allows very short absorption when in storage or very light use. The time can automatically extend when the start value is lower. And for extreme use there is a setting for very low battery to stay in absorption all day.
If you go on the low side you can set equalization a bit higher say 14.8 to give them a boost every so many days you program.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
