EV2
Sep 12, 2016Explorer
MrWizard wrote:
Some of this is going way off course
The no bond generator is not and never has been a converter problem
FYI
I have used wfco converters with inverter generators, open frame, and Onan
Never ever a ground conflict
You really should share your expertise with WFCO tech support so that you can correct them. The WFCO in one of my trailers will not pass convert 12v from my Honda 3000, UNLESS THE GROUND & NEUTRAL ARE BONDED. The same with a neighbor. Remove the bond plug = fail. Reinstall the bond and it works. Tech support advised contrary to your remark so contact them and advise that your advice supersedes.
I have nothing else in between the trailer plug and the generator, so please advise why it fails.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
