BFL13
May 29, 2013Explorer II
The Honda on eco is less noise than when running full, but the way the eco works is that the engine revs up as needed to run the load, so it can be just as loud as with the eco turned off, depending.
Even so, the Honda at full revs is very quiet compared with those low cost generators.
Now define "less noise." You can have a high amp charger that wants more watts (VA really) for the first stage of charging, then amps taper, with the Honda getting quieter as amps taper. The louder part at first being short in time depending on the battery bank size and initial SOC just how short.
Or, you can go with a low amp charger that runs a long time to do the recharge but at a quieter sound level the whole time.
I use a Honda 3000i on eco with my 100 amp PowerMax converter and the gen does not make much noise over idle when doing the 100 amps.
Which raises another idea that the bigger size gen will stay closer to idle on eco than the smaller gen with the same load? So you might choose the 2000 instead of the 1000 even if the 1000 can handle it. I do not have any idea how much difference in noise there would be in that example though.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
