pianotuna
May 29, 2013Nomad III
Hi Fisherman,
And you get to change the oil every 100 hours, and pay for fuel (currently $5.269 per US gallon here) and carry spare fuel, and fill it with fuel, and have it run out of fuel at 2 a.m. and carry it from place to place, and worry about it developing feet (and disappearing). Also, sooner or later, it will require replacement. You also get to pull start it. Don't try that in truly cold weather. You also get to worry about keeping the battery banks charged between trips. Probably you get to replace the house batteries on a much more regular basis.
Most likely the "turnip next over" has a poorly installed and under recommended size wattage system, with an inadequate number of amp-hours of battery bank. Send him to us here, and we can help him optimize what he has, and make recommendations for an upgrade.
Personally, I run out of fresh water before I run out of 12 volt power or 120 power. BTW I've spent twice as much on generators as I did on my solar system. The generators are "long gone" and the solar system just keeps on trucking.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
