pnichols
Jun 06, 2013Explorer II
crcr wrote:
I seen those EX650 gens come up on ebay from time to time. Do you know what year they quit producing them? What do they weigh? What is it, 650 watts output? Thanks.
You probably missed my 2nd post earlier where I provided a link to a chart comparing the specifications on a lot of the older small Honda constant speed generators. As you've found out, many of these good old 3600 RPM Hondas can be had for a song with plenty of good camping years still left in them.
Here's the link again:
http://www.tappedin.com/hop/html/litegen.htm
I'm not sure when they stopped producing the EX650 - around the late 1990's, or 2000, I think. I also was recently given a Honda EX1000 in like new condition and I'll use it outside around our residence instead of in the RV because of it's 64 dB noise level - too high for battery charging when camping. I'll keep the little EX650 (it's at least 25 years old) in the RV for it's ultra-quiet sound level of 54dB.
I have nothing against solar, but I think it should only be part of the total power mix for a well-equipped self-contained RV. Here's what I think are two very flexible setups for RV power generation in all conditions (in addition to a large battery bank and an inverter or two):
A) The next best setup - portable solar panels (not on the roof), small quiet generator for battery charging when the sun can't do it, large quiet-as-you-can-afford generator for hot weather/high humidity air conditioning.
B) The best setup - portable solar panels (not on the roof), fuel cells for battery charging when the sun can't do it, large quiet-as-you-can-afford generator for hot weather/high humidity air conditioning.
The reason I'm a fan of portable solar panels is that you can move them into the sun if you're fortunate enough to be able to park the RV in the shade and/or if you're paranoid (like me) about not having any more holes in the roof than what you already have. I also don't care for how roof mounted solar panels restrict access on the roof ... I want to be able to crawl all around up there to wax it, make modifications, and repair/inspect stuff.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
