- pianotunaNomad IIIHi,
I'd go one step farther than SMK and add an inverter. Use the golf cart batteries/inverter to operate the shore power cord on the RV. - I still like 2x 24v solar panels on the golf car. You would be the hit of the campground.
About $500 for panels and controller. - mena661Explorer
Old & Slow wrote:
In a really quiet setting, any generator will seem loud. IMO, I would try to limit the genny usage to as little as possible which means fast charging and larger battery banks. I'm not out long enough to charge batteries using the genny so fast charging isn't a priority for now. I do use the genny for running the convection oven until I get some solar and a larger inverter. Honda and Yamaha genny's are as quiet as they come but are pricey. Pnichols idea of running a Honda EU3000 at low loads is a good one but to my ears the EU2000 is quieter.
BLF13,
Thanks for the post. It's so sad, we all have the live at times with 'cause and effect'. I hate loud noise. The gens of yester-years... except for the Honda EX650? I want one that I can use and still hear the crunch of walking steps and the dog sled runners in the snow (memories) O&S
Floyd - pnicholsExplorer II
Old & Slow wrote:
In favor of the Honda 1000i, the pioneer of box building (he lives I think, in Oak Harbor WA) built a box for the Honda 1000i and put hundreds of hours on it with no heating problems. It purred like a real kitten. So I know the air flow was fine for the Honda.
I guess I should disclose my full current situation regarding portable Honda generators: Just this past Sunday my brother gave me outright a Honda EX1000 (900 watts continuous) red generator. It's in immaculate like-new condition with maybe two hours run-time on it with all of it's shiny tools still in it's built-in tool box. Since it's sound level is 64dB - too loud for RV camping if used as is - maybe I should find out what the pioneer of box building did for a 1000i and duplicate it for my "new" EX1000. Perhaps I can get my EX1000's apparent sound level down into that superlative and magical no-generator-sound-for-all-practical-purposes realm of where a Honda EU3000iS is (at 1/4 of it's rated load) - 49dB!
FWIW, here's a specifications comparison chart link for most of the good old Honda 3600 RPM non-inverter suitcase generators - many of which can still be picked up for a song for routine RV battery charging via the proper chargers:
http://www.tappedin.com/hop/html/litegen.htm - Old___SlowExplorerBLF13,
Floyd - BFL13Explorer II
Old & Slow wrote:
......I would rather run the inverter more hours at the most silent rate than charge fast and ferrous with a screaming gen. I feel with the info' coming down the pike (thread), I'll find the answer and go from there. Thanks for all the help thus far.
Floyd
You don't get that choice in BC provincial parks, eg, where there are gen time limits of 9-11am and 6-8pm. So to get it all done (a 50-90)in two hours you want a fast charger (high amps, 14plus volts) and enough gen to run it for your size bank. - Old___SlowExplorerI have little doubt that the Honda EX650 will go down in history of successful and winning gens. If I were to guess, I'd say In my time on RV.net forums, I've seen at least 100 posts praising the little fellow. The info' left by pnichols is what I was looking to find. I always wanted to believe the 1/4 load figures should indecate the ideling output, giving the lowest dBA rating. Personally, I would rather run a gen longer at the lowest dBA rating than be on the upper end of the scale, noise wise. Also burning less fuel. Most folks say that batts are better served with a slower charge rate. In my old age I have forgotton, perhaps, more that I ever knew about batteries. But in the old days I don't remember bulging dry batts in my RV's. Anywho, for my single purpose need to charge the 24v sealed lead acid batt in my scooter and considering the Yamaha 1000i, it looks like I can expect around 250w at the lowest rmp. Or 400w from the 2000i Honda or Yamaha at 1/4 output.
Thanks, pnichols for yet another great post, there have been so many really helpful good folks, in a 'quest' to charge the batts with the least noise.
In the mean time, back at the ranch, I'll be on the lookout the a Honda EX650.
Floyd - pnicholsExplorer IIThe Honda EU2000i runs at a 53dB sound level when delivering about 400 watts (1/4 of it's 1600 watt continuous rating).
My Honda EX650 runs at a 54dB sound level when delivering 550 watts (all of it's 550 watts continuous rating).
Since my RV's battery bank usually charges initially at no higher than around 30-35 amps anyway, I'll probably stick with our little EX650 as long as I can keep it running. Our EX650 is around 25 years old and still starts right up even after leaving it setting around with ethanol blend gas left in it's tank, fuel line, and carburetor. It's engine is four-cycle, so no mixing.
I know most folks seem to love to buy brand new, but FWIW, one can still find the Honda EX650 used in the $200-$300 range. - mena661Explorer
Salvo wrote:
X2
The noise rating for Honda 2000i and 1000i are identical: 59 db at rated load and 53 db at 1/4 load. If noise is a big factor, then the 2000i will charge the batteries in half the time at the same noise level.
Sal - SalvoExplorerThe noise rating for Honda 2000i and 1000i are identical: 59 db at rated load and 53 db at 1/4 load. If noise is a big factor, then the 2000i will charge the batteries in half the time at the same noise level.
Sal
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
