- SalvoExplorerHey Floyd, you must be an expert on noise reduction generator boxes. Are you getting tired of that yellow one?
I think you're attacking this issue from the wrong point of view. The econ mode will not limit power to 400W. The gen will rev up to whatever power is demanded.
You really want to know which converter will work with a 2000W inverter/gen. You want to minimize gen run time and charge batteries as fast as possible.
Sal - I am thinking a solar panel or two on the golf cart. (~450w) A panel on the RV. (~225w) Then a 300w inverter on the RV to charge the scooter :B
$1500 and you are all set. - HiTechExplorerDepending how much you are willing to tinker, there are certainly ways to charge the scooter from the big battery bank in the Club Car, or bring along more battery capacity on the scooter to extend its range. As you mentioned the least intrusive (but less efficient since you are on a power budget and a small genset) is to have an inverter and power supply. Even on the scooter you could carry along a battery to charge back up.
More work but better results could be had by expanding out the scooter's direct battery capacity.
Something like This could give you 500w of power from the 48v batteries in your Club Car.
Jim - mlts22Explorer IIIf you have the space for it, I've seen people put up wind turbines, using a pipe attached to their rig, perhaps an additional section to get it higher. Here in central Texas, there is always wind to catch, and you get four times as much power when the wind speed doubles.
Dunno about noise though. I am going to look into this because I park my TT at the same place for a quarter of the year, so if a 400-600 watt windmill is quiet, even if it just trickled 50 watts/hour on average, it would go a long way to offset the furnace fan and other loads. - Old___SlowExplorerYC1,
Old saying is true, 'there is more than one way to skin a cat'. Or quiet a gen. and not wake up the chickens maybe at 4am.
This thread is always awesome. It will cause one to go on the hunt for the ol' thinking cap and then too, some one will come through with great info' thanks,
Floyd - YC_1NomadHeck, I use my 1000 at times to keep my 40 ft DP charged while boondocking. The charger has to be turned down or it will trip the little genny. I run a long cord off into the trees if possible or use one of those portable round trash cans that collapse and set it almost all the way inside. Drop a towell over the top and it is even quieter.
- Old___SlowExplorerI just knew this was the right place to post a question. I did not fully list all my needs. Being old and now really slow, I have three types of batteries. One, my electric scooter is 24v sealed lead acid. It uses the charging block AC100-240v 1.8a input, output DC24v --@ 2a__I always fear going to far and running out of battery power. (therefore the thought of some way carrying a small inverter) and it could also be brought along on the Club Car 48v golf cart. Being Old is enough, don't need to create lots of noise. Then last is std 12v batts.
Thanks for helping return to my starting point, with no worry.
Floyd - HiTechExplorer
Old & Slow wrote:
Without solar;
Lots of 1000i/2000i inverters on the market. If I am correct, they output about 400w on econo (low noise). How much 12v charging can be accomplished with just 400w ?
Pretty much every 20 amp charger will work, many 30 amps and possibly a 40 amp running at maybe 36 actual if it has a good power factor and amazing efficiency. For max power and lowest throttle I'd go for something with a 30 amp setting to stay below 400 W.
Jim - mena661ExplorerIMO, the Honda 2000 is quieter than the 1000. If I were buying a generator, it would be the Honda 3000 like BFL or the Yamaha EF4500. I've heard the EF4500 and the EF6300 and both were ridiculously quiet for what power they provide.
- 2oldmanExplorer IIThe question was pretty simple.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
