JiminDenver's avatar
JiminDenver
Explorer II
Jul 11, 2015
Charging the Lifelines questions
As you all know, anything more than clipping the auto charger onto a battery is well above my pay grade, so I have some questions.
For the regular charge before the conditioning charge, the Lifeline manual calls for a voltage limit of 14.3v at 77 F for absorb. I am assuming that is the point I have the controller switch out of bulk. Correct?
Second thing is the Eco-W can handle doing that but can only handle one panel. That's not much of a C rate on a 8-D. Is it worth setting up that system to work on bringing one of the batteries up while the big system does another, or should I just work on them one at a time?
I'll start searching through the post for what stand alone charge I will have to get to plug in at home. I am not interested in a fancy converter since the trailer never gets plugged in to anything but the solar.
