MEXICOWANDERER
Jul 11, 2015Explorer
Lifeline spells out what they like to see in equipment and maintenance. They are an engineer oriented company. Their military battery mil-spec manuals are similar. It isn't that Concorde batteries are diffetent - it"s other AGM OEMs are less rigid and precise in their maintenance recommendations. Look through the threads and I covered this in exhaustive detail. You can treat a Fullriver or an Exide or a Deka according to Concorde recommendations and the battery will live longer when on a float maintenance and MUCH MUCH longer if cycled and not underpoweted when being recharged. Not being correctly recharged is the big killer with any AGM battery. Stop. Think. Is 13.3 volts a correct float voltage at 15F ? Of course not. And THAT is a big-time killer of ALL AGM batteries. This is why hou will NOT find a set voltage batterh tender on my premisis. Weather temperature trends change slowly enough to allow manual volrage adjustments. If you want automatic that is correct it will have a remote thermistor temp probe and a volt per C taper that agrees with the LIFELINE curve which is the correct curve for any and all AGM batteries.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
