landyacht318
Jul 13, 2015Explorer
Mex are you saying Lifelines 20% minimum recommended rate can be nullified by more time spent at 14.4v?
My Northstar AGM holds high voltages for longer during the next discharge, after a higher amp recharge, even when the low and slow solar holds 14.4 to 14.7v long enough for amps to taper to 0.4.
My observations of the NS AGM behavior would indicate it very much appreciates higher initial amps when depleted to 50%
