JiminDenver
Jul 20, 2015Explorer II
Ok Mex, the Megawatt is here. Earlier you mentioned
One Megawatt 36-ampere power supply adjusted to 14.4 volts would make a suitable charging source for each 8-D but one of the two polarity bridges would have to be opened to isolate the circuit for the sake of the Megawatts.
and
At conditioning values, the AGM will vent. No question. Use a SIX HUNDRED WATT rated DROK DC to DC booster as found on Amazon. Set the voltage while booster is connected to the Megawatt. The booster must have a fan played across the heatsink to endure this power level.
You will have to explain the polarity bridge part and I am assuming I wont be able to get above 13.8v with it until I get the booster. Correct?
Ok I see on the site that it's adjustable to 15.5v. I'll wire it up and see what' what.
and
