landyacht318
Jul 20, 2015Explorer
With just one megawatt, no worries. Mex parallels his and these require some isolation from each other.
Adjust voltage to 14,4v unloaded and let it loose on the 8d until current drops to 0.5% for the 20 hour rating.
If trying to achieve conditioning, a voltage booster will be required to get voltage above 15.5v and it must be capable of handling nearly the full output of the Megawatt when first applied to an other wise 'fully' charged battery
If it were my Used lifeline I was trying to get in line with the other 2, , I would just max out the voltage on the megawatt first and apply it for a good while, before delving into lifeline's prescribed 'conditioning' or deep discharge procedure.
Your solar has just nt been able to hold high voltages for long enough. The Megawatt can.
