MEXICOWANDERER
Aug 10, 2015Explorer
Hook up the battery
Is a little confusing.
Exactly where is the spark taking place?
Non transformer power supplies have a lot of capacitors to charge up. I like the idea of using a 20-amp rated AC toggle switch to turn the main power on or off. Or better yet, an Intermatic timer which makes it impossible to forget to turn it off. 15, 30-minute, 2,6,12 hour models. Spring-wound 20-amp rated.
The BEEG ESPARK is the reason for the 4-pole switch. From off to the Mega # 1 switch to position 2, then both Megas come on line. Alternative is to run down to the front desk and explain why the hotel fuse blew.
Placing order NOW with allelectronics.com
THANK YOU MISTER WIZARD!
