JiminDenver's avatar
JiminDenver
Explorer II
Jul 11, 2015
Charging the Lifelines questions
As you all know, anything more than clipping the auto charger onto a battery is well above my pay grade, so I have some questions.
For the regular charge before the conditioning charge, the Lifeline manual calls for a voltage limit of 14.3v at 77 F for absorb. I am assuming that is the point I have the controller switch out of bulk. Correct?
Second thing is the Eco-W can handle doing that but can only handle one panel. That's not much of a C rate on a 8-D. Is it worth setting up that system to work on bringing one of the batteries up while the big system does another, or should I just work on them one at a time?
I'll start searching through the post for what stand alone charge I will have to get to plug in at home. I am not interested in a fancy converter since the trailer never gets plugged in to anything but the solar.
  • RoyB's avatar
    RoyB
    Explorer II
    My wet cells would boiling fluids big time at that VOLTAGE and CURRENT. I'm betting your AGM's will still be venting Hydrogen Gas during this process. Definitely would keep away from open flames, sparks, and red hot elements... My wet cells will start bubbling even at 13.6VDC in the NORMAl MODE. When it drops down to 13.2VDC STORAGE MODE then the bubbling stops. If i was running 14.3VDC verses 13.6VDC in the NORMAL FLOAT MODE it would be raining battery fluids haha...
    In my PD9260C charging uses the same 14.4VDC for the EQUALIZE MODE EVERY 21
    HOURS FOR A PERIOD OF 15 MINUTES. This is the highest DC VOLTAGE I will see on this charger. 15.7VDC at high currents would scare me as well even for a short period of time...
    I am old enough to remember the days where the automotive shops would put 50VDC on a battery with 200AMPS of DC CURRENT available to be used. This was their quick two hour charge. They also had signs around that they would be not be responsible for replacing the battery if the top blows off... I saw go over the shop roof one time... People would be lined up waiting to be next haha...
    Roy Ken
  • Thanks.
    After seeing some of the charging threads on here, 14.3v just seemed low. The conditioning/ equalization voltage is 15,6v and the recovery, that's just plain scary. lol
    Charge at a constant current of 5 % of rated (20 hour)capacity until the voltage reaches 15.6 volts (7.8 volts for a 6 volt battery), then continue charging at this rate for an additional 4 hours. Note that the charging voltage may get as high as 18.0 volts (9.0 volts for a 6 volt battery)
    , so the power supply must be capable of outputting this level to maintain constant current. This constant current charge may take 16 to 20 hours.
    Yes, bulk -> absorb -> float
