Acampingwewillg
Feb 20, 2018Explorer II
I'm under the bed now as we speak(engine access), I'll be cleaning up the grounding lugs with a wire brush/Drill wire brush and since I'm there, I'll make up some new 2/0 grounds from the batteries. I've also added a new ground lug just for kicks to be absolutely sure I'm getting a solid ground. As this is a 96 motorhome and after reading the actual build sheet/comprehensive owners manual, I have found that most wiring has been done with 2/0 cabling and here I though I was upgrading it.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
